Difference between folder autopopulating and snapshot
in project explorer while adding folder  there are two options
Folder Autopopulating and Folder Snapshot what is difference between them
regards
mazhar
(8,568 Views)
Autopopulate will update the project folders contents when they are changed outside of labview (ie you drag a vi into an autopopulating from windows) while the snapshot will not continiously sync to the file system.  I usually use autopopulating folders.  The disadvantage of autopopulating folders is that your project hierarchy is the same as your file system.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(8,563 Views)
thanx
but if i use snap shot and update some vi is that vi also update in project explorer
when i use autopopulating it doesnt allow me to delete any file or folder of that auto populating foldr in project explorer
(8,557 Views)
Yes Deleting a vi from an autopopulating folder will delete it from disk as well, this can be done from the file tab in the project explorer (you an also rename and move from the file  tab).  In a snap shot deleting from project leaves the vi file unchanged but will remove the reference from the project.
Paul Falkenstein
(8,544 Views)
By design, LV does not allow you to directly delete files from autopopulating folders. You can do it from the File tab in the project window, but only by right clicking on it and selecting "Delete from Disk". You can however rename files from either tab.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(8,528 Views)
