Difference between Voltages in time frames!
I am working on LabVIEW for analysis on temparature measurements.  Can anyone help me out-- how to find the difference between two voltage values in two time frames?  I get continuous values of varying voltage from USB module(ez430 RF2500) every second, for example, at time t0 -- 0.415V , at t1 --  0.425V, ......continuous...i want to display the difference between the amplitudes between two time frames continuously (present and previous) in a waveform chart!  Can anyone suggest any method/VI for above!?
Thanks in advance!
Message 1 of 8
(3,877 Views)
Hi aarief,
 Can you post your VI for continuos acquisition of data with samples for every one second?
Thanks and regards,
srikrishnaNF
Srikrishna
Message 2 of 8
(3,860 Views)
Hello Krishna,.
I have designed the VI for normal single read of buffer string, but i run the VI in continuous mode, the USB module sends data to Labview via VISA Open nd VISA  Read and i have done few modifications on strings to get the values. As i need the differences in values to be displayed, i am trying using converting into array thn array functions,then finding difference. Do you have any idea how to find out the difference?
I run the VI in Continuous mode to read the buffer continuously!
Message 3 of 8
(3,852 Views)
Hi aarief,
  Since you are acquiring data at the rate of 9600bps...so for a second you will acquire 9600 bits means 800 floating values.....if you acquire a value A,then after 800 values ,if your acquired value is B..then you need B-A ..isn't?
Thanks and regards,
srikrishnaNF
Srikrishna
Message 4 of 8
(3,841 Views)
Hi krishna,
Yes, That will be one difference value, as i get continuous data buffers till i keep VISA Read running,i want to have difference between consecutive values (present nd previous) continuously to display the differences in a waveform chart
Thank You,
Aarief Hussain
Message 5 of 8
(3,839 Views)
Hi aarief,
  For that as you use a while loop for continuos acquisition...place a shift register and initialize with zero...and now read the value from read function and substract the value from the left...Just check the attachment..
Thanks and regards,
srikrishnaNF
Srikrishna
Message 6 of 8
(3,828 Views)
Hello Vamsi,
Im new to LabVIEW (learning),
What is the function you have used for string to DBL?
Can you forward me the VI?
Aarief
Message 7 of 8
(3,822 Views)
Hi Krishna,,
I got the function(scan from string),, i have to implement in the VI..
Thanks alot! I guess this will work!
Aarief.
Message 8 of 8
(3,819 Views)
