Difference between Low level and Normal IMAQ ?
There are two options in IMAQ palette a low level and a normal one. Both have the same function names and the same icons the only difference being the balck and white icon of low level functions and colored icons of the normal functions. What is the difference between these two and what is the need of making a low level palette of functions ?
Regards
Asad Tirmizi
Design Engineer
Institute of Avionics and Aeronautics
" Its never too late to be, what u want to be"
Using LabVIEW 8.2
(2,907 Views)
Low level imaq functions gives you relatively more function to control the hardware. Buffer functions is one which is not there on the high level palatte
(2,896 Views)
