Difference between 1D Array
Hello guys,
I want to compare two 1D Arrays. And  I want to  calculate the maximum deviation and the minimum deviation. How can I implement that?
Message 1 of 8
(2,869 Views)
Subtract the 2nd array from the 1st and do an Array Min-Max?
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 8
(2,867 Views)
Does I need an for loop or while loop?
How can I use an boolean, to say that my derivation is in my range I rhought on range and coerce.
Message 3 of 8
(2,864 Views)
Accepted by topic author medum
You mentioned nothing of In range in your 1st post. See if this helps.
Qestit Systems
Message 4 of 8
(2,857 Views)
Why i dont have for-Loop and while-Loop
Message 5 of 8
(2,840 Views)
We really don't know what you have or don't have, but nobody needs loops to compare arrays.
Message 6 of 8
(2,825 Views)
Many functions handles arrays automagically.
Qestit Systems
Message 7 of 8
(2,759 Views)
Thank u very much!
Message 8 of 8
(2,754 Views)
