Developing more sophisticated enum control methods
I would like to select a function name and map it to a module and channel.  For instance, it would be much better to specify "Cold Water Flow Rate" than to specify "Module 3" and "Channel 7" which have no real meaning.  How can I develop something like an enum but with immutable data with more than one dimension?  I'm thinking the best solution is to make an enum of the function names and use it as an index into an array of module and channel enums but the array is not immutable, or is it?  What other methods should I consider?
(2,685 Views)
Accepted by topic author kc64
An array is not immutable.  But is Module 3 or Channel 7 something which will never change? What if you get a new DAQ device with different channel numbering?
Make the array a diagram constant or read the data from a configuration file and then do not change the values in the array within the program.  Then index as you mentioned.
Lynn
(2,674 Views)
