Online shopping is currently unavailable.
Please contact us for help or try again later.
‎06-29-2009 12:16 PM
When I try to run an installer I built but keep getting this error:
"Developer Error. The following erroer were found in your ini file:
1. Missing Key:[UserInfoDialog]RegSProp
Correct the ini file and try again.
Details:
.\ConfigInfo.cpp(2896): Installer Error 11006
Developer Error. The following errors were found in your ini file:
1.Missing Key:[UserInfoDialog]RegSNProp"
I'm working in 8.2.1 but tried to build the installer in 8.5 as well. Same error either way..
Any thoughts? This is my laptop and I haven't used it for installers before. I've had zero installer issues with another desktop PC.
Thanks for any help!! ![]()
Joshua
‎06-30-2009 04:29 PM
What laptop are you using? Are you running both 8.2 and 8.5 on it?
Ipshita C.
‎06-30-2009 04:41 PM
Hi Ipshita,
It is a Dell, not sure of the model off hand. It has 8.2.1, 8.5 and 8.6 beta on it.
Thanks!
‎07-01-2009 03:18 PM
Hi Josh,
The reason for this getting this error is usually a corrupt installation CD in which case you would have to try to get another one. Another reason can be leftover registry keys from a previous LabVIEW uninstall, in which case you would have to clean your registry using MSI-Blast (from NI) or the Windows Cleanup Utility. As you recently installed a new version of LabVIEW and your installer started showing this behavior after that I would go strongly for this reason. A third reason may be that the installer is not being run from the hard drive which I do not think is valid in your case as I assume you are not trying to run your installer from a CD. I hope this helps.
Ipshita C.
