Determining the direction of quadrature encoder in Labview
Hi Brosa,
yes, the NI-6212 is your DAQ card.
Read its manual to learn about its counter capabilities.
Message 11 of 12
(729 Views)
Ok Using the window where you found the DAQ device you can set up your channel as a quad encoder:
Here is how you do it.
Open NI Max again and locate the Data Neighborhood option. Open it and fine the NI-DAQmx Global Virtual Channels. Right click and select Create New NI-DAQmx Channel.
Next This window will Pop Up:
Click on Acquire Signals:
Then click on Counter Input:
Then click on Position:
Lastly click on Angular Position.
Next this window will pop up:
You can select what counter you have wired your encoder to and click next.
Give your channel a name and click finish:
Now this window will pop up. You will need to set up your channel.
Update the Input terminals to the correct channels where you have them wired on your device. Hit save at the top. If you have done everything properly and it is wired properly. Hit run and you should see the encoder counting.
Tim
GHSP
Message 12 of 12
(724 Views)
