Determining if sensor is overrange or open
Has anyone written code to determine if any of their sensors are overrange or open? Most vibration analyzers on the market have LED lights on the hardware to show that a channel is overrange or open.  I guess that is some of the reason National Instruments bought IOtech a couple years ago.  My code is not broken into separate producer and consumer loops using queues, and I was debating whether to do the Overrange/Open check before DAQ or inside my DAQ loop incase a sensor goes bad.
(3,408 Views)
Some of the NI DSA hardware has open short detection built in.  What NI DSA hardware are you using?
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(3,403 Views)
8109 controllers with 4472B and 4462 modules
(3,382 Views)
Hi LabViewer,
Here a a link to the NI Dynamic Signal Acquisition manual.
http://www.ni.com/pdf/manuals/371235h.pdf
According to this manual, page , the NI 449x has per channel open an short detect. The 446x series, page A-10, has pre-digitization and post-digitization overload detection. The 447x series, page A-22, has postdigitization digital overload detection only. Starting on page 2-5 the manual details how to uses these features in LabVIEW using DAQmx Read property nodes. Please let me know if you have any additional questions.
Josh B
(3,363 Views)
Josh that is helpful but with the 4472s and 4462s it sounds like there isn't channel "open" detect in the hardware.  So, I guess I'll have to do it in code. The only way I can think to do it is by DC coupling the accelerometer since you can read a DC voltage (~11V) if the accel is working and then if it is open the DC will go to ~22V. I'd have to do this check initially before I go into my normal DAQ process where I AC couple the channels.
(3,349 Views)
You are correct, there is no "open" detect in the hardware. The explination you provided should work as long as you know what the expected voltage should be for a functioning circuit versus an open one.
Kyle K.
Product Manager for Product Data
(3,323 Views)
