Determining if running in dev environment/debugger attached with a realtime application
Is it possible to determine on RT if you're for lack of a better term "running" in the dev environment? The App.kind property will always return Embedded LabVIEW whether or not it's a build. I'm sure that's because it deploys an EXE and attaches the development environment. I'm not using it for anything critical, but just changing some timeouts depending on the environment I'm in at app startup.
(353 Views)
Hi Greg,
Have you tried using a Conditional Disable Structure ?
Raphaël.
(317 Views)
@raphschru wrote:
Hi Greg,
Raphaël.
Nope, will see if that does it!
(267 Views)
