Determining if LabVIEW is open from a built application
I'm trying to determine if the LabVIEW environment is open from a built LabVIEW application. Is there an ActiveX property or method that tells me what apps are in memory? Maybe something in the Windows API?
Any info would be appreciated.
John
(3,197 Views)
I use the Open G Tools for that situation. The Get Task List.vi will return an array of strings listing the running applications.
Michael Munroe
www.abcdefirm.com
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
(3,197 Views)
If you are only interested to know if your VI is of built application or is of development VI... perhaps this will be able to tell.
ian
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,197 Views)
Thanks Michael,
I received another suggestion on how to use the Windows API (User32.dll) to detect LV in the background which worked very well. I'm going to take a look at the site you referenced also.
Thanks again for the response,
John
(3,197 Views)
Thanks Ian,
Actually, I already know that my VI is built as an application. What I needed to do was give my built application the ability to see if the LabVIEW environment is open on the local system. Someone sent me a suggestion to check the Win32 API (User32.dll) and it worked very well.
Thanks again for taking the time to respond,
John
(3,197 Views)
Why don't you just use a property node and use the application>>all vi's in memory. This will work fine in an executable or a DLL.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(3,197 Views)
