Determine Memory Available
Does anyone know how to programatically access the information in the task manager? I need to know how much memory a system has, how much is being used, and how much is in page file.  Thanks,
Nate
(3,383 Views)
There's a nice example in the Example Finder that can help you get started (from LabVIEW: Help >> Find Examples). Simply browse to the category called Communicating with External Applications >> .NET and then launch the VI called SimpleTaskMonitor.
You should be able to modify it to accomplish what you want. Here's a link on using .NET in LabVIEW.
Jarrod S.
(3,379 Views)
You can use a vbs script file and system exec. Check the script repository in the hardware, memory section and the operating system, pagefile section.
http://www.microsoft.com/technet/scriptcenter/scripts/default.mspx?mfr=true
(3,362 Views)
