Detecting front panel close without an event structure?
Is it possible to detect a front panel close without using an event structure? If so, how?
Message 1 of 8
(4,918 Views)
You could poll the front panel's state in a loop.  Why don't you want to use an Event structure?
Jim
Message 2 of 8
(4,896 Views)
I have a series of while loops being executed until an analog user input is detected. Basically I want to be able to control the exiting behavior of a subVI whenever the user closes the subVI's front panel before it has completed.
Message 3 of 8
(4,889 Views)
Use the panel close? filter event and you can discard the actual close event (from closing the front panel) and use that to tell your loops to shutdown/exit etc.
(blog)
Message 4 of 8
(4,883 Views)
Im trying to stay away from event structures, in a previous post i was told that having all of the while loops in the event structures "gums things up" and that i should use a state machine. So i switched to a state machine and now I just need to handle a panel close.
Message 5 of 8
(4,880 Views)
Have the Event structure in a parallel loop and send messages using a queue, notifier...
Jim
Message 6 of 8
(4,863 Views)
No - have a seperate loop with just the event structure and register for the panel close. In the panel close? filter event, use some method to tell the other while loops to shutdown. Look at the producer/consumer (events) template/example.
(blog)
Message 7 of 8
(4,860 Views)
Having an event structure (good!) has nothing to do with having interactive while loops inside an event structure (bad!).
Message 8 of 8
(4,801 Views)
