Detecting change in edit position of a table control
@Warren Massey wrote:
Darin came very close to providing the answer I needed with this answer. He just got "Return" and "Enter" backwards.
Not backwards for what I was suggesting.  Smiley Wink  The method I suggested would change a Return (which moves to the next element) to Enter (which does not) when used on the last row.  This way Return moves you down the Table until the last row.  You happen to be turning all Enters into Returns and then cleaning up afterwards if necessary.  As long as it works, it is all good.
Message 11 of 12
(934 Views)
Can you please provide the code? I have trouble locating the VI's you used.
Thanks in advance.
Message 12 of 12
(864 Views)
