Detect rotation direction from 2 pulse train
I need to calculate the rotation direction from 2 pulsetrain that are 90° phase from each other.
Its 24V signals (high) and im using NI9423 on a cRIO-9047.
Somehow i need to decide which one of the pulse train that goes high before the other, and also the opposite for the other direction.
If someone can provide some example code it would be much appreciated.
After the calculation i need to set a boolean to TRUE if it goes to the right and FALSE if it goes to the left.
(1,032 Views)
Hi tokar,
You just need to keep track of the current and previous state of both pulse trains, so all you need is a shift register!
Turning "right" will go FF, TF, TT, FT (typically for A rising before B), the other direction will go FF, FT, TT, TF…
(1,021 Views)
Thank you for reply,
why do i need shift register?
looks like just the current state to me?
Can you provide a short labview code example?
Easier to understand then
(1,008 Views)
Hi tokar,
Because "movement" is defined as "difference between previous and current position"!
And encoders give you the current position…
It's just a comparison between previous and current state. (And state is defined as combination of A and B value.)
(1,006 Views)
Accepted by topic author tokar
Some practical questions first:
What is the frequency of those pulse trains?
What is the electrical specification for those digital signals?
What is the hardware you intend to use to read those digital signals?
These answers will determine very much what route you will actually have to go. If your signal is anywhere in the 100 Hz or higher ranges, a simple digital input with software detection is going to be bound to miss level changes and cause your detection to be inaccurate.
If you have a DAQ card with a general purpose counter you can let that counter do pretty much all the work for you even for very high pulse frequencies by using the Edge Counting mode with the optional Direction input on the according Aux input. It's basically a bi-phase signal counting operation.
If you have a (c/sb)RIO FPGA hardware you can program everything even for very high pulse rates in the FPGA fabric of your device.
Since you seem to have a cRIO-9047 and a 9423 you should be able to go up to several 100kHz pulse input rate.
There are various examples that come with LabVIEW about implementing a bi-phase counter on FPGA with simple digital IOs.
Yes it involves shift registers to be able to compare the previous digital state of both IOs with the current one in order to detect the logic level changes, aka slopes of your signal. The most simple implementation is nothing more than this:
However things can get a lot more complicated in real world. Input signal debouncing might be a requirement if your signal is not a nicely defined pulse.
Also you might want to have some additional detection about if the actual source is moving at all (meaning causing a minimum amount of pulses per second, millisecond or whatever). And if you are at it you may also want to maintain a count value.
After having added all this, your solution will have led you into the abyss of digital circuit design for sure. 😁
Rolf Kalbermatter  My Blog
(966 Views)
Thx for your reply!
- Pulsetrain will go up to 2kHz
- The signals are 24V for the pulse
- My hardware to receive the pulsetrain is NI9423 o a cRIO-9047
So i think 10kHz will be enough to capture my pulsetrains.
Capacity is no problem 😊. Can sample higher if needed.
I also have code to detect if its moving at all.
Calculating ticks between pulses give me the time and movement.
I tested your code example and it works perfect :).
Thanks alot for your help!
Problem solved 😊
(926 Views)
