Detect USB Stick insertion
I am trying to write a LabVIEW app that will be able to detect that a USB stick/key has been inserted into the computer. I know that I can get the names and serial numbers of all the drives that are currently mounted. However, I do not know how to check to see if one of them is a USB mass storage device, more specifically a USB stick as opposed to a USB-attached optical drive.
I could just check the size of the device and if it is under 4GB assume that it is a USB key. But if there is a more elegant way of doing it that I can be more sure of, I would like to do it.
Using LabVIEW 8.2.1
Kyle
Message 1 of 9
(12,266 Views)
You could try the VI mentioned in this LAVA thread.
Or, you can try this C# class.
Message 2 of 9
(12,256 Views)
Thank you. I think I am just going to go with the polling with the list directory VI every 100 ms or around that. Just compare the new list of drives to the old ones, if there is a new one I will take the action that I want.
I think the environment is controlled enough that we won't have issues with that. No one will be swapping drives out like mad (or at least they shouldn't be!).
Kyle
Message Edited by Kyle Thompson on 05-29-2007 08:07 AM
Message 3 of 9
(12,154 Views)
For those interested, take a look Device Monitor Demo at:
George Zou
Message 4 of 9
(12,086 Views)
I need to detect the USB stick insertion in cRIO RT 9014? List Directoy/Folder does not list the driver names in cRIO. It lists the ni-rt folder only. How do I detect the USB stick insertion and copy a file to the USB memory from cRIO RT.
Thanks in advance.
A Senthilnathan
Message 5 of 9
(11,511 Views)
Hi A. Senthilnathan,
The USB stick insterted in your cRIO RT 9014 will show up as the u:/ drive. To access it, you can ftp into the cRIO by going to ftp://xxx.xxx.xxx.xxx/u😕 .
Thank you for choosing National Instruments.
Aaron Peña
http://www.ni.com/support
Message 6 of 9
(11,463 Views)
Hi Aaron Peña,
Thanks for your help. It works good for me.
A Senthilnathan
Message 7 of 9
(11,444 Views)
This is my problem too (Detect USB Flash inserting)
But your program does not work. Does it ? I got an error while opening it by LV2010
Message 8 of 9
(10,411 Views)
To monitor USB devices I would recommend using this C# Class as recommended above.  Good Luck
Message 9 of 9
(10,365 Views)
