Detailed Help not working
Open up a Windows Explorer window and goto Tools->Folder Options or go to Control Panel->Folder Options.  Find the CHM extension:
 Click on the Advanced Button.
Select the open action and then click the Edit button.
Check to see if the settings match mine.
Message Edited by Matthew Kelton on 01-07-2009 01:17 PM
Message 11 of 15
(3,103 Views)
Matt,
My configuration matches yours exactly..still not luck
Message 12 of 15
(3,090 Views)
There are known infection of hh.exe, so maybe it is infected and your antivirus blocks access to it. Check your AV log or system log for interesting entries.
Maybe you should submit your hh.exe to an online virus scanner, such as Virustotal.
Message 13 of 15
(3,083 Views)
Accepted by topic author Jeff_Giacone
I found a fix for the problem at the following link
http://bubble.ro/Cannot_Open_the_File__Mk__MSITStore___Error_Message.html
The HHCTRL.ocx file got messed up somehow
Here is where I got a good file from
http://www.ocxdump.com/download-ocx-files_new.php/ocxfiles/H/HHCTRL.OCX/4.73.8412/download.html
Thanks for everyone's advice
Message 14 of 15
(3,069 Views)
Good work!  Thanks for posting back with the solution.  This will help others in the future if they search the forum for the same problem.Smiley Happy
Message 15 of 15
(3,055 Views)
