Desktop Execution Trace Toolkit not showing the name of the VIs
Hy
My Desktop execution trace toolkit is not showing the names of the vis in wich the events ocour. I´v tryed everything i could possibly think of so far... but nothing worked. Does someone knows how can it be fixed?
Desktop execution trace toolkit error
Message 1 of 8
(4,511 Views)
Interesting. What version are you using (LabVIEW and DETT)? Could you share your project so that we can try to replicate this?
Message 2 of 8
(4,481 Views)
What does the details field display when you select an entry?
Norbert
Expert: Geometry
Message 3 of 8
(4,451 Views)
My LV version is 2014 and the DETT is also 2014. My project is quite big to be sent over and has a lot of components, and the funny thing is that this error ocours only in this particular project. I made a stripped out version of it so you can try to reproduce the error. This error ocours in this stripped version too. I tryed with other projects and it worked. BTW my server configurations are:
Message 4 of 8
(4,424 Views)
The project is the following. It wont make sense, since is just a part of a bigger project, but the error ocours in this little version too. Just execute Main.vi
Message 5 of 8
(4,423 Views)
When i click on an item from the list it displays the dialog attached. But all of the vis in this project are in the local computer.
Message 6 of 8
(4,422 Views)
You have quite a lot of VIs and ctls in your user lib which are not part of your source distribution. Therefore, we cannot review the execution.
As a personal advice: I do recommend to remove special characters which are non-english. Even though experience shows that LV can handle such names, there have been cases where it did NOT work.....
Norbert
Expert: Geometry
Message 7 of 8
(4,400 Views)
About the names with special non-english caracteres, i have never had a problem with them so far. Still, thanks for the advice regarding this subject. Its not a bad idea to folow it. I created another project, this time includind all of the vis, even the ones within libraries. I hope you can execute it this time. Note that you might get a lot of conflict messages, since you labview will try to load some vis from you internal libraries.
Message 8 of 8
(4,395 Views)
