Design of Function Generator
I am new with LABVIEW. I would require to design a Function Generator using Labview. I need help with the step by step process for developing the VI module please.
(1,896 Views)
Accepted by topic author AyeshaZaman23
There are built-in function generation VIs under Signal Processing >> Waveform Generation palette. You don't have to build one from scratch.
There are shipping examples under C:\Program Files (x86)\National Instruments\LabVIEW 20xx\examples\Signal Processing\Signal Generation folder as well.
If you are not sure how to use those VIs, explore examples and read the help file.
If you want to output the signal through hardware, you would need to specify which model of device you will be using.
https://tmesystems.net/
(1,892 Views)
