Depth First Search (LIFO) - stacked based
Hi Everyone,
Herewith attached my workable Breadth fist search (FIFO) code - queue based. Now, I would like to change to LIFO - stacked based.
Anyone here can give some guideline on it?
Many thanks.
(4,812 Views)
Use enqueue data at the opposite end, and normal dequeue will give pretty much the same result as stack.
(4,789 Views)
Hi KateB,
i've just realized that the attached code is queue stacked based which is meaned queued LIFO. What if I want to change to FIFO? what should i change? Any guideline on it?
(4,782 Views)
use simple enqueue functionSmiley Wink
(4,764 Views)
I've changed it to queue FIFO. but in the end, it won't show a complete path to reach the destination point. However, queue stack LIFO can show a complete path from starting point till the goal point.
Does that means queue FIFO cannot be used in finding a complete path out? Is there any possible way for this method to find its way out?
Herewith attached queue FIFO.
(4,760 Views)
So when is your homework due?
(4,744 Views)
Hi Intaris,
On this coming week.
(4,739 Views)
