Deployment utility missing from Tools menu
I'm using NI TestStand 4 (Development system) and I only get Customize... button on Tools -menu. There used to be Deploy TestStand System button but now it's gone. Any ideas what is wrong? I don't remember doing any changes to TS Sequence editor or LabVIEW.
(2,422 Views)
Your 'Tools.INI' file within the C:\Program Files\National Instruments\TestStand 4.0\Cfg directory was either deleted or moved.  Once TestStand restarts, it creates a default file upon opening.
Just copy the 'Tools.INI' file from another PC if available.
PH
(2,409 Views)
