Deleting same elements in array and their rearrangement based on other array
I need to delete duplicating characters in a string array. In addition the rearrangement in these new string characters should depend on their position alon the X axis given in other array. Any ideas how..
Cheers,
Z
p.s. In the attachment u can see my attempt and in the help.vi u can see my attampt.
(3,184 Views)
I'm not quite getting what you're trying to do here.
I think it all may start with the Match Pattern vi though.
Can you work up an example of your inputs and outputs?
(3,174 Views)
Your question is not clear.
It would help if you could place some default data into your arrays of the VI and also include an indicator containing the result you want based on the default input.
Now make the currentl values the default, then save and re-attach the VI. Thanks!
(3,170 Views)
Guys I solve the problem. Sorry for not explaining the problem so much but I am kind of restricted due to non-disclosure reasons.
(3,153 Views)
