Deleting repeated elements in 2D array
Hi all,
Would be grateful if there is someone can help me to delete the repeated elements in the 2D array as in the attached thread. Thanks in advance
Message 1 of 11
(5,340 Views)
@Al-rawachy wrote:
Hi all,
Sorry, your question is not specific enough to give an answer.
What do you mean by "attached thread?" I looked at the attached VI and it has only 1D arrays in it, not 2D.
What do you mean by "repeated elements?" Is that any element, or matching rows, or matching columns? If you mean any element, then what do you mean by delete? Setting it to default for that datatype, or NaN?
Message 2 of 11
(5,332 Views)
Try this.  The first element in any array cannot be duplicated by default.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 3 of 11
(5,307 Views)
  • You have a 1D array, not a 2D array.
  • All values seem to be integers, so why do you use an orange datatype? With DBL, equality is difficult.
  • "delete from array" is dangerous unless you delete the last element, because all indices of existing elements change. It should never be used repeatedly in a loop.
  • Have you heard of the conditional output tunnel? It would significanlty simplify your code.
  • (I would probably use a variant attribute base solution.)
Message 4 of 11
(5,287 Views)
Accepted by topic author Al-rawachy
As said before, if you have integers, change the data type of your input 1D array to I32.
If you use LabVIEW 2017, there is a VIM to do this for you in one step. If you have earlier version of LV, you can download the OpenG Arrays toolkit from VIPM, and use that:
Message 5 of 11
(5,270 Views)
Thank you guys for your help. it is really helpful
Message 6 of 11
(5,257 Views)
Hi Blokk,
+1 kudos from me for your really helpful post!
Could you maybe elaborate a bit more on where you found the VIM? I have LabVIEW 2017 Professional installed but could not find this VI. I only found the openG version on my machine.
Thank you a lot!
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
Message 7 of 11
(5,219 Views)
@ikaiser wrote:
Hi Blokk,
Thank you a lot!
Hmm, I might have used accidentally my LV2018 beta at home when posting to this thread. I do not have access right now to LV2018, but I guess this is the case. Anyway, LV2018 is now officially released and accessible, so I do not violate the NDA 🙂
Message 8 of 11
(5,213 Views)
@ikaiser wrote:
Hi Blokk,
Thank you a lot!
Just for the reference, the above mentioned vim is not an NI one, neither exists in LV2018. I totally forgot that some time before, I installed a package from LAVA, so that vim is from Hooovahh:
https://lavag.org/files/file/296-hooovahh-array-vims/
Message 9 of 11
(5,156 Views)
You can also use Variant attributes with the side effect of the output array also being sorted.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 10 of 11
(5,147 Views)
