Deleting a control from a typedef Cluster
Hi 1984,
Its like if I would delete an element from an array and as a result the rest of the elements would get scrambled.
Yes, they get scrambled - when you insist on using constant element indices! (Those references seem to work like "reference of n-th element of your typedef cluster"…)
Why do you need all those references on elements of your typedef?
Message 11 of 36
(3,372 Views)
Because if I have a massive cluster on the UI, its hell lot easier and less space consuming to get the value of a given element by a property node than to read it with unbundling the cluster.
Plus there are tons of cases when I dont just need to read or write. I may need to start blinking something, use a value (signaling) property, change the background color of an element etc etc
Message 12 of 36
(3,365 Views)
Hi 1984,
Great misconception…
So you have a typedef that is made to create a DATATYPE description - but you start to fiddle with UI look?
Then separate your typedef from your UI…
Message 13 of 36
(3,360 Views)
OK, reading Gerd's answers it seems I totally misunderstood what is going on here.
Static references to cluster contents?  Heck no, don't do that.  If you MUST get references to the individual items, put the logic in a sub-VI and use the sub-VI with a cluster input to get the individual references back.. This way you have ONE location to fix.
Now that I understood the magnitude of the problem I have to say this behaviour is NOT a bug, it's bad programming.  It's so far from what I would consider doing I didn't see the treed for the forest  Smiley Indifferent
Or as Gerd says, decouple your data structure from your UI altogether.
Message 14 of 36
(3,355 Views)
"Great misconception…"
No its not. It is actually easier and less space consuming. Although I see you are a person who is alway right, right?
Message 15 of 36
(3,340 Views)
Ok... it could be bad programming. (Not sure if that changes anything, but the original post is purely about the property nodes and not about references. I know references are a different animal).
So if its bad programming what should do with about 150 different controls. So far I have used a cluster, which bundled them into one nice structure, now I will have 150 separate controls. With a cluster when I had to do anything with its elements I just created a subVI with the typedef'ed cluster input and did it inside.
So in other words how should I handle 100+ controls without completely messing up my block diagram?
thx,
Message 16 of 36
(3,344 Views)
Hi 1984,
No, ofcourse not.
But as long as you only describe what you are doing and as long as I read "bad programming behaviour" I will say so…
Usually you use an event structure to handle UI events!
This will end in a while loop and an event structure with a lot of cases…
Nobody said you have to use 150 separate controls. You can use clusters or arrays - but you should not tie them to your typedef cluster when you want to change that typedef repeatedly…
Message 17 of 36
(3,330 Views)
I use event structures extensively. The problem I forcast for myself is that while so far I had everything inside of an entity I could read an event of lets say a "value change" of a given control, then drive the entire cluster drive into a subVI and do math / operations inside. Now as my controls are separated, I somehow have to drive them individually into the subVIs. And as each subVI does different things in each case of the event stucture I have to deal with the individual controls. This is a LOT less unified solution as each VI need to have different inputs and also a lot less scalable as if I add a new control I may need to change lots of subVIs.
example: user changes the value of ctrl1 and to validate his changes I want to check the contents of 15 other controls, numerics - booleans - strings - enums mixed. With a cluster its easy, but if everything is separated I need to create a subVI which receives these 15 different controls and do the math inside.
I understand the approach that a typdefed cluster is a datatype and not really a UI element. But using it as the part of the UI has so much benefit over using separated controls that I must think that the issue I have described at the beginning of this topic is really an issue with labview.
Message 18 of 36
(3,322 Views)
But HORRIBLY EXPENSIVE.  Property Nodes are absolutely the slowest way to get a value from a control/indicators.  You would be much better off keeping a copy of the cluster in a shift register so that you can unbundle/bundle the elements you need to.
Message 19 of 36
(3,317 Views)
I am not arguing that part... (although in my app that slowness is acceptable)
The problem I try describing is that I dont need the values only. I made the cluster as the part of my UI which has lots of benefits. And by simply using a shift reg. I can't access properties except but the values, while I need a lot more.
Message 20 of 36
(3,310 Views)
