Delete just three items from the right clic menu of a waveform graph
I would like to delete some fonctionnalities from the right click menu of my waveform graph. If i use the specific function "delete menu", it works only if I want to delete all the right clic menu. But if I write the name of the specific item that i want to delete, this function returns an error.
What's happening?
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(2,590 Views)
I think you're trying to edit the default shortcut menu of an application item, which isn't allowed.  Another way to do this is to right click on the Graph->Advanced->Run-Time Shortcut menu->Edit
Select Custom and then add in any items to want to be displayed.  This easily creates a customized menu.
2006 Ultimate LabVIEW G-eek.
(2,576 Views)
It works perfectly, thank u very much!!
(2,567 Views)
