Delete an USB device
I manage several USB Devices with a Labview application under windows XP. I would like from this application delete the device properly before to turn it off. how is it possible?
(2,886 Views)
I don't know of anything native to LabVIEW that will turn the USB devices off like you would like. I imagine there is a Window�s SDK call, or some dlls out there that do turn off or delete the devices. If you can find those dlls you could use a Call Library Function Node in LabVIEW to call the code.
(2,886 Views)
I did some more searching. Take a look at this discussion of stopping card socket devices. I am assuming that the same theory applies to USB devices.
How to "Stop" a PCMCIA card programmatically under NT
Hope that helps.
Evan
(2,886 Views)
There is nothing native in labview to turn off an usb device (anwser from Ni). I'm sure that threre is a dll in windows to do this ant that i can call it. The question is which Dll and wich function of this. And how to find this
(2,886 Views)
