Delete Plot names
Hii,
I have predefined  plots in a graph & for a new Project I want to delete ´some of the existing plots.
There seems to be no way to do the same from graph properties.
Has anyone some suggestions for the same.
regards,
Akshay
(2,450 Views)
Hi Akshay,
delete all plots:
1. Right-click the graph indicator and select Data operations -> clear graph
2. Right-click the graph indicator and select Data operations -> make current value default
Delete some plots:
1. Change your VI to only supply the needed plot data, then run it.
2. Right-click the graph indicator and select Data operation -> make current value default
(2,430 Views)
