Delete Custom Scaling
I have close to 20 custom scales in daq assistant from previous experiments.  Is there any way to remove custom scales that are no longer needed?
(2,987 Views)
Hi there,
Your custom scales are actually managed within the Measurement and Automation Explorer (MAX). If you open max and expand the scales category on the left hand side, you should see all the scales you have created within there which you can right click and delete as required...
All the best!
(2,983 Views)
