Delay recording data using "write to measurement file"
Hi there,
I am collecting data using DAQ Assistant, and write the data to file using "write to measurement file" functions. I set up an analog trigger signal in the DAQ assistant so that the data will be writen to file after a falling edge signal is triggered.
I would like to delay (about 100 ms) writing the data to file after a trigger signal is being sent. I couldn't figure out how to do so. Hope you can help. Attach is the VI file. Thanks a lot.
YK
(2,378 Views)
Use the Reference Trigger and read the LabVIEW Help for more Information about it.
Christian
(2,372 Views)
