Delay before sending signal
Hi guys,
I need help on this urgently. 😞
See attached photo.
I have a case structure with Boolean True/False of Time Elapsed attached to it. Once the time has elapsed, it will trigger the case structure. However, I would like to have a 3s or more time delay before the case structure is triggered. How should I do this ?
Thanks ! Gracis merci.
Message 1 of 13
(5,075 Views)
The picture doesn't tell us much except you are probably misusing local variables. What have you tried? What's the problem with adding the 3 seconds to the elapsed time function? Where's the case statement? Why can't you insert a delay function in there so it's called before the existing functions you have?
Message 2 of 13
(5,068 Views)
Hi Denis please help.
What I need is to delay before executing a case structure. Please see attached photo. The case structure is inside a while loop.
The local variable will signal to execute the case structure. However, I wish to delay that signal.
Thanks !
Message 3 of 13
(5,053 Views)
And I have you a couple of ideas. If adding the extra delay to the elapsed time does not work, then put it inside the case statement as I already said. A simple way is to put a flat sequence structure around the code inside the case statement. Add a frame before and in that frame, put a Wait (ms) or a Delay function.
Message 4 of 13
(5,043 Views)
Use Time Delay with 3sec and then pass the error wire into case structure.
uday
Message 5 of 13
(5,041 Views)
p.s. If you need to delay both cases, then a flat sequence structure outside can be used.
Message 6 of 13
(5,037 Views)
pps I suspect you are adding this delay because of a race condition caused by misusing local variables. The suggestions I made may work but still a hack.
Message 7 of 13
(5,030 Views)
Hi Udka,
Addint time delay into the case structu re does not work as now it delays the execution of the case stucture at each iteration of the outer while loop. Do you understand ?
Hmm what I need is to delay the signal before it starts executing the case structure... without delaying each iteration of the while loop....
Message 8 of 13
(5,019 Views)
I told you to keep time delay before case structure and then pass the error wire to case structure.
-Which means the case structure will execute when the error wire comes out from time delay block (Remember Data Flow using error wires??)
uday
Message 9 of 13
(5,016 Views)
Hi Udka,
The problem is, because of the outer while loop, at each iteration of the while loop, the time delay of 3s will be in effect and thus the case structure will be delayed every 3s at each iteration of while loop.
What I need is to only delay 3s for the first time and subsequently the case structure will execute without any delay. Hope you understand.
Thanks a lot guys !!!
Message 10 of 13
(5,011 Views)
