Default Probe for Array of LVClass
The ability to assign a Default Probe for a class is great! It makes encapsulating the class so much simpler if you use custom probes.
How do you assign a Default Probe for an array of said class? There isn't an option for it in the Class Properties. Is there such a thing as a Polymorphic Custom Probe???
(2,473 Views)
Thanks for pointing out that feature. It was something I didn't know about but will start using now.
I don't have a solution for the array default, but if no one has a solution, you could create an idea in the Idea exchange.
Certified LabVIEW Architect
(2,408 Views)
That's the next step if no one points out a method I've missed. I'm just not really hopeful anything will happen in LabVIEW Classic since NXT is coming.
(2,391 Views)
