Decrementing an integer through a .vi
Greetings,
I am creating a .vi that simulates 2 processes running side by side (Proc #1 & Proc #2) up to a variable limit. The processes each increase via a random number generator per some multiple. The multiple for each starts at 10.
After the .vi execution is complete, the process that reaches the limit first, will decrement the multiple by 1 through the .vi to prepare to run again or have the choice of stopping the .vi. through the two button user input.
The process will be started again by selecting a "go" button from the front panel. After the limit is reached the process can be stopped or decremented again...and so on. (The 'go' button is not shown on the front panel).
I am stumped on how to decrement the variable... Attached is what I have so far. Any help is greatly appreciated
(3,421 Views)
Is there a reason for it to step back down? If you simply restart the code you have right now it will start at the beginning (0) again.
But to get it to step back down, you could create another shift register that contains a boolean value. Put case structures around the addition operators and wire the boolean value to the selection node of the case structures. Make sure the addition is in the false case, and put a subtraction operator in the true case. Now, starting with the value initialized to false, you count up until one of the processes reach the limit. But instead of stopping, the boolean value is set to true and you start counting back down. Stop the loop when either of the process values are less than or equal to zero AND the boolean value is true.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,418 Views)
oops - duplicate...
Mike...
Message Edited by mikeporter on 11-07-2007 11:40 PM
LabVIEW Champion
(3,418 Views)
Thanks for your reply, but you lost me at "But to get it to step back down, you could create another shift register that contains a boolean value. Put case structures around the addition operators and wire the boolean value to the selection node of the case structures"
Where do I create another shift register and what is the selection node of the case structure? I apologize for the "novice" questions because I am a novice!!!
I appreciate the help and patients for us beginners trying to learn the ropes!
Newbie 2
(3,410 Views)
The first thing to do is go through the "getting started" materials that ship with LV or take a LV Basics course. That will teach you about shift registers and case structures - and a bunch of other stuff besides. Where are you located?.
Mike...
LabVIEW Champion
(3,406 Views)
I am located in upstate NY.
I will look through LV materials and your instructions to get through this.
Thanks!
(3,383 Views)
You can also contact your local NI rep to look into class availability, or call my company (DSA @ 724-942-6330) and we can also talk to about getting hooked-up with LV training.
Mike...
LabVIEW Champion
(3,369 Views)
