Decode variant data w/o using 'Variant To Data' function.
I need to decode variant data w/o having foreknowledge of the type used to create it. That is, I'm using the 'Flattened String To Variant' function which gives me the info I need, but it's all contained within one indicator. I need some way to break this info down into its constituent elements.
For instance, let's say I have the flattened data and type descriptor from a cluster with two elements, a boolean and a string, but not the structure itself. Passing this flattened data and/or the type descriptor into a function, I would get a 2D array (or the like) as output containing the name of the boolean (its label), its value, and the name of the string and its corresponding value.
There must be a way to
do this, and I suspect it's been done already, but I can't find any reference to it.
I have attached a file named Test.vi which demostrates this problem.
Remember, even though I know the name of the control, I won't know the type, so I cannot use the 'Variant To Data' function to deference these values. I can make ready use of DLLs, CINs, or LabVIEW code for the solution.
Thanks ahead of time for any help! Greg
(3,049 Views)
You might be able to take advantage of the Variant to Flattened String VI from the Advanced>>Data Manipulation>>Variants pallette. This VI converts a Variant to a flattened data string and a type descriptor. The type descriptor is explained in ap note 154. You might be able to create a VI that would parse data from the flattened data string using the type descriptor. You might have to represent each piece of data as a flattened string to work around the data flow issues in LabVIEW.
(3,049 Views)
