Decimal value not displayed after decimal point in my snippet
The decimal value is not getting rounded to its nearest integer in my unswitched pack volatage display box. I have changed its property to decimal, still the problem continues. When I put a probe between the divider and the display box, I get correct values. How to get correct value in display box.
(2,623 Views)
Accepted by topic author aditya1992
See the color (colour if you're from UKSmiley Wink) of wire where you're hooking a probe... its orange (that represents floating point number).. but the color of indicator (other name for unswitched pack volatage display box) is blue (U32, it means it is unsigned integer representation in 32 bits)...!!
if thats the issue... then try one thing... right click on the indicator (other name for unswitched pack volatage display box) and select "Representation >> DBL", as shown below..!!
this should work...!!
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,616 Views)
thnx man ,....it works .... 😄
(2,612 Views)
