Hi All,
I need to convert decimal to hexidecimal, so as to input this to an array. I've tried the solutions posted already for a similar problem, but they aren't suitable.
I cannot use the number to hexidecimal string function, as I need the output as a single number, not a string.
Also writing the decimal number into an indicator, and changing the number type to hexidecimal is not an option, as I would then need to use a local variable to read this value to an array, but this isn't a good idea as I need to do this for many numbers at the same time, (I am trying to send data to CAN).
Hence is there a simple way to create for example a sub vi, which takes in a decimal number, and outputs it as hexidecimal?
Cheers,
Emmanuel
