Decimal marker values
I have an XY graph wich Xscale is continuously modified by a scale multiplier corresponding to a period of rotation  of a cylindrical piece.
According to the rotation speed of the piece I am modifiyng multiplier and therefore the Xscale of my XY graph.
My issue is that the XY graph only print Xscale values as integer, and the result of the multplication of the scale is not always an integer, so I'd like to know how can I print Xscale value on the XY graph even if they are decimal.
Olivier
(2,831 Views)
Hi Olivier,
you should set your own marker values using the appropriate property node. See the attachment!
(Don't forget to adjust the formatting options of the x-scale to show more than 1 digit. Smiley Wink)
Message Edited by GerdW on 09-20-2007 02:37 PM
(2,816 Views)
