Decimal Point in Lab View Measurement File
Hi
Just one quick thing
I'd like to use the LabView Measurement Output, to output data to a text file (which works).
BUT: I'd like to use a comma as decimal point (as it is usual around here). Is there some way I can achieve this ?
(2,734 Views)
You can't. The decimal point is hardcoded into the express vi.
If you're curious enough, you can check the following thread, discussing a similar problem:
http://forums.ni.com/ni/board/message?board.id=170&message.id=132738#M132738
(pay attention to the format string)
Paolo
Paolo
(2,728 Views)
alright .. thank you ...
already thought it would be like this ... 😞
(2,724 Views)
