Debug runtime loaded dynamic dispatched VI in executable
Hello everyone,
i have a problem which i cannot wrap my head around and i hope someone can provide an answer. I was messing with the MGI solution explorer example (log data into HTML or CSV depending on loaded class) provided where there is a dynamic dispatched VI loaded from a class in a PPL file during runtime. My problem is the following:
-I want to debug the different overrides of the d.d. VI
-If i open the VI in development env. without the child classes loaded into memory then as expected i can only open the VI of the parent class
-After loaded them into memory i can select which override i want to open (as expected)
The problem occurs if i decide that i want to debug the d.d. VIs from a debuggable exe which calls them:
-I build the exe as debuggable  and open a debug session and everything is working fine but even if i load the classes into memory i can not select the overrides for the d.d. VI.
I hope someone has experienced a similar problem and have a solution for it. (BTW i am using LV2015 and i am attaching the example provided by MGI)
Thank you in advance!
-Imre
Message 1 of 1
(2,670 Views)
