Debug and deployment Licence. Transitioning from PCI I/O Cards to cDAQ
Hi all.
I’m currently working on transitioning an existing application developed on Labview from PCI I/O cards to a cDAQ system with I/O cards. I have a few questions regarding the debug and deployment licence and the extent of changes I can make to my existing program:
  1. Can I perform this transition using a Debug and Deployment license, or do I need additional licensing?
  2. How much flexibility does the Debug and Deployment license provide for modifying my existing program? For example, can I make significant changes to the code, such as adding new functionality or restructuring parts of the application?
  3. Am I allowed to completely overhaul the HMI (Human-Machine Interface) under this license? For instance, can I add more information, or other features to improve the user experience?
Any guidance on these points would be greatly appreciated. Thank you in advance for your support!
(361 Views)
Technocally there is no difference between the Debug license and the according Full license.
Legally however is the Debug license meant for two things:
1) Debugging of an existing application on a target system. This also allows for minor programming changes that are required to fix bugs that are found during debugging.
2) Running an existing application on a target system in source code because building an executable is to troublesome or deemed ineffective. Usually this also turns sometimes into above debugging but it does not have to.
Your intended changes clearly are a redesign and stretch the term debugging by far beyond any reasonable limit.
However since you probably have an old perpetual Development license (after all someone beford you originally did develop that application somewhere, right?) you might consider making use of a promotion from NI where you can upgrade to the latest version of LabVIEW for the standard SSP price of 25% of a full perpetual license without any late fees until June of this year.
You just have to find proof of the original license purchase as NI obviously requires some proof of an existing old license to make use of this offer.
Rolf Kalbermatter  My Blog
(331 Views)
