Debug Window / Probe Watch Window broken
Hi everyone,
in the latest release LabVIEW 2025Q3, NI announced this new feature:
Troubleshoot VIs Using New Debug Window
The new Debug Window added in LabVIEW 2025 Q3 combines probe and breakpoint management in a single location, and replaces the Probe Watch Window.
The Debug Window lists breakpoints and probes for all VIs in memory, and allows you to add, remove, rename, highlight, and export data for probes and breakpoints. You can also use the window to enable and disable breakpoints, switch probe styles, and create custom probes.
You can use the Debug Window to customize the window appearance, as well as if probe values appear directly on wires in your VI block diagram during execution
[Idea submitted by NI Discussion Forums member Citabria].
To my problem:
I am using LabVIEW for Linux RedHat 9.4.
With this update I am struggling to use the "Debug Window" which opens up, when putting a probe onto a wire for example.
This window then continuously closes and reopens and makes further operation impossible, unless you somehow manage to press the exit-button at the right time.
Is someone else experiencing this problem?
P.S.: I tried to sent a bug-report to NI but everytime I am filling the fields and confirming the web-site throws an error, hence my question in this forum. I attached a screenrecording.
Message 1 of 1
(718 Views)
