Dealing with Positive and Negative Binary Values - Modbus Project
I have a motion control system and I am receiving register values for velocity. I am receiving 2 register values, 1 for the integer (Register1) and 1 for the decimal (Register2).  Each register is via U16.
Example:
Register1 = 1
Register2 = 54823
Since I am dealing with U16:
(1x2^16) + 54823 = 120359 units/s
This motion system can also have a negative motion.  When this happens
Register1 = 65525
Register2 = ***** (arbitruary value decreasing as negative motion continues)
Since Register1 is maxed (1111 1111 1111 1111) this tells me that this system uses ones or twos compliment to deal with negative velocities.
How can I construct a VI to deal with both negative and positive velocities?  Any ideas?
Danny
(3,421 Views)
Use typecast and type cast your U16 value to an I16 value.
(3,412 Views)
As an expansion to the recommendation by Ravens Fan you can do it like this.
Rolf Kalbermatter  My Blog
(3,406 Views)
Thanks rolfk!
Looks great, but the values I will be recieving in my registers are not definite.  They can and will be going negative and positive.  So my many concern is how to design this portion of the system to distinguish when the registers are showing a negative number vs when the registers are showing a positive number.
Danny
(3,389 Views)
ACtually!,
NVM it works great 🙂 Thanks rolf
(3,386 Views)
