Dealing With Non Uniform Array Sizes
Yes, if you have a FOR loop, the final array size is know, so preallocation might be more efficient as Lynn pointed out.
If you don't know the final array size (e.g. using a while loop), you code can still be simplified:
  1. initialize the shift register
  2. use "build array" instead of "insert into array"
  3. ...
here's how it would look like, clean up a little bit.
Message 11 of 13
(910 Views)
Thank you! It seems so easy now..
Message 12 of 13
(885 Views)
So I'm down to the last step. The program I've attached does what I want except I can't plot the final array. I apologize if the programming is messy, I'm just trying to throw this together before the day is over.
So to clarify I'm just trying to plot the "element" cluster. I need to convert it to something the graph can read but it's telling me "You have connected to a polymorphic terminal that does not accept this wire type " When I try to convert it to an array.
EDIT: I've got it. Just needed to unbundle it. Thanks everyone!
Message 13 of 13
(875 Views)
