Date string returns inconsistent results
I use the function Format Date/Time String with the format argument "%d%b%Y_%H-%M-%S" to get a string which looks like "01Oct2004_11-01-45". The built application returns the same, however when the application is run on a PC in South Korea the string "01102004_11-01-45" is returned. What is wrong?
(2,755 Views)
Hello leifk,
it seems they don't have an abbreviated month name 🙂
I think, it depends on the operating system and the country settings. Perhaps Labview can not work with the South Korean font (or unicode or whatever) and replaces the month name by the number...
Btw. I would use "%Y%m%d" to have a alphabetical / numerical sorting order.
Best regards
(2,755 Views)
I need to obtain %d%b%Y in order to produce "05Oct2004" which is most compatible with SQL insertion into our internal databases (DB2 of course).
My solution:
I wrote a function which gets the current datetime as a cluster and then constructs a datetime string. I placed the 3-letter month names in an array and select the month name by month number.
(2,755 Views)
