Date/Time to Second
I am trying to create a custom timestamp with the node Date/Time to Second.  I am not sure why, but regardless of what input I feed it, I always get 00:00:00.000 PM MM/DD/YYYY.  Why is that?  See code.
(3,037 Views)
What is the data that you're trying to operate on? Can you attach the VI with some default dummy values set?
(3,028 Views)
Hi jyang72211,
  Somewhere the data which you are giving is invalid.Please verify the Help of that Date/Time to seconds Vi and check the input data.
Thanks and regards,
srikrishnaNF
Srikrishna
(2,992 Views)
My guess is in the month part.
If you enter a month <1 or >12 the 'Date/Time to Seconds' will return what you are seeing.
(2,959 Views)
I have to agree with what's been said.  It's impossible to evaluate how the VI performs without seeing the data it is operating on.
Jim
LV 2020
(2,953 Views)
Sorry, I just had wrong input.
(2,908 Views)
