Datatype problem in project euler
Today I had nothing to do, so I participated in Project Euler http://projecteuler.net with Labview. I'm at question 10 now. The question itself isn't much of a challenge, but the problem I'm having is that the datatypes are to small for the value I would like to put in there. The value first goes up, then changes from + to - and then goes back to zero. This all happens while I'm just adding up to the value.
I guess there is a sollution to this problem but I don't seem to find it. Is there someone who can and will help me please?
(3,765 Views)
What datatypes are you trying to use?  Are they integer or floating point?  How many bytes?
(3,743 Views)
For example:
Calculate the full value of 2^1000. Even if I use the 64bit datatype I come in (very) short.
Thank you very much for your response!
(3,733 Views)
by the way, I am using integers because the result has to be accurate. In the end I need the sum of all numbers of the result.
(example: 456789 becomes 4+5+6+7+8+9 = 39 and the 39 is what I need)
(3,724 Views)
Well, the link you gave said problem 10 was "Find the sum of all the primes below two million", a little different problem than 2^1000.
In order represent 2^1000 at full resolution, you would need a 1000 bit number!  Of course a U64 won't be able to hold it.  A double will hold it and it comes to about 1.07...e301, so 301 decimal digits.  But a double won't store the full resolution.
In order to do what you want, you will have to set up your own math functions using 125+ bytes.  You will have to do the multiplication and do all of your own carries.  That why they made it a problem, to challenge you to figure out the algorhitm to do it.  Otherwise going 2^1000 in any programming language is a trivial exercise.
(3,714 Views)
