Datasocket stops sending data to OPC Server
I have been having a longstanding issue using Datasocket and LabVIEW 6.1 to communicate to a KEPWare KEPServerEX. I have resolved most of the issues, save one, and would like some input on what might be happening.
Most of the time the software works correctly, sending a boolean watchdog as well as about 10 other tags (most are never updated; 2-4 can be updated at 1s max). There are also about 20 tags which I must read information from the server.
The issue is that somewhere around once a week to once a month for 30 seconds or so the software stops updating the watchdog that I send to the OPC Server, then all of the sudden starts updating again by itself. I have already installed the LabVIEW 7.1 Run-time engine to get the most updated version of Datasocket, as well as using the older compatibility VIs that are included with LabVIEW 6.1.
I am using the WriteAutoUpdate and the ReadAutoUpdate modes for the datasocket references. Has anyone had any similiar problems with Datasocket and OPC?
(2,445 Views)
Sirin,
How do you observe this issue? Is there an error??..do you have a timeout indicator??
Also...have you looked at network spikes that may be happening with the DSS drops??
-Brett
(2,433 Views)
