Datasocket Problem
Definetely think its a network issue...Make sure you don't have Windows Firewall running, that will block the socket connections.
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
Message 11 of 13
(969 Views)
I tried my program on another network and it worked ok. I can't find out what's blocking it on my LAN though? I have tried it with Windows Firewall turned off on both machines and I don't have any luck. The client app is reporting Error 54 - illformed network address. I get this if I use the hostname of my PC. If I try the IP address I get error -2147014831 (undefined).
I can't understand what I need to change on my computer or my router to allow DataSocket communications? I've had this working before. Can anyone help?
Message 12 of 13
(951 Views)
Message 13 of 13
(949 Views)
