Database toolkit stored procedure return String
Hi all,
How I can return the entire string from my stored procedure using the attached code ?
With this code I only retrive the first caractere of the string return by the stored procedure.
Thanks for your help.
MHP
(3,611 Views)
HI
I have the same issue
Did you found something?
(3,228 Views)
First, assuming that you are using the database connectivity toolkit, I would recommend that you not burden yourself with it. Database IO is really very easy, though you would never know it working with the DCT.
Second, unless you are using the exact same code, you don't know if you're having the same issue. Please show some code.
Third, what DBMS are you using? What does the stored procedure do? What is it supposed to return?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,217 Views)
I can't upload code online. NDA
Which solution did you apply?
(3,212 Views)
Do you have a link for Database IO ?
(3,204 Views)
Start here:
http://www.notatamelion.com/2015/01/05/managing-data-the-easy-way/
And read the following couple posts...
Mike...
LabVIEW Champion
(3,197 Views)
