Database toolkit problem
Hello
I have a problem with running DB toolkit.
After installation I try to open example or build very simple code with DB Tools Open Connection.
The result is broken arrow shows me that the DB ..Open connection.vi is not executable.
I have installed LV 8.5.1 and DB toolkit from CD. All examples are visible after loading DatabaseEx.llb
but none of them are possible to run. All of them have the same problem, DB .vis are not executable.
I have Developer Suite packet. CVi is installed on C://Program  Files, but LV is installed on D://
Does it be a problem for DB toolkit ?
In LV I can see all DB*.vi in Connectivity tree.
Where I made a mistake ?
Konrad
Message 1 of 12
(5,600 Views)
Which OS are you running LabVIEW on? XP or 2000? LabVIEW database toolkit depends on the MDAC, http://www.microsoft.com/downloads/details.aspx?FamilyID=6c050fe3-c795-4b7d-b037-185d0506396c&displa... From you desciption, it seems this component is missed on your computer.
Message 2 of 12
(5,588 Views)
My OS Windows XP SP2.
MDAC 2.8 is currently installed on my PC.
What do you suggest ?
Konrad
Message 3 of 12
(5,583 Views)
What error message did LabVIEW tell you ? Click the broken arrow you can find the error messages.
Message 4 of 12
(5,575 Views)
My procedure looks like that:
Tools>>Create Data Link the window Error list appears where: No VIs with errors.
 When I close this window then I can see: Initialize.vi with broken arrow and the same Error list.
When I open block diagram then I see Prompt and Open UDL.vi with broken arrow....
Second case: I create empty VI, put DB Open .... with some reference and Run. Errors -->look into .jpeg
Property node is set up on unknown control Connection... Where is this control ?
KNRD
Message 5 of 12
(5,564 Views)
I think that the problem can be connected with my folder installation.
CVI is already installed on C: (in CVI DB Toolkit works correctly).
LV is installed on 😧
When I install DB Toolkit then there is no window to change installation path.
Maybe, by default, the DB installer create something in C:\Program Files\National Instruments\ forder
expept in D:\NI LabView\Database.
In D:\NI LabView\Database\MDAC  in mdac_eula.txt is something about Microsoft Data Access Components 2.5.
Which version should be installed on my PC ? How to check ?
Konrad
Message 6 of 12
(5,539 Views)
Hello
I made some system check.  MDAC already installed on my PC are:
- MDAC 2.8 SP1 on Win XP SP2
- MDAC 2.8 SP1 redistribution
Does DB toolkit cooperate only with MDAC 2.5 ?
Does NI dosn't have DB toolkit for 8.5.1 and MDAC 2.8 ?
Konrad
Message 7 of 12
(5,511 Views)
Hello Konrad,
I have the same MDAC installed and the DB toolkit is working. I use it with LV 7.1, but this shouldn't care.
Paolo
Message 8 of 12
(5,506 Views)
On my PC doesn't work.
I think the problem is with ADO connection object...
Conn ObjectReference.ctl .... connection reference, there is dotted wire.
I reinstall LV and DB tool, problem still exist...
Help, I need this urgently :-((
Konrad
Message 9 of 12
(5,489 Views)
Try to reconnect the control to the proper object. Follow this procedure:
1) go to the front panel and right click on the _Connection terminal, then select ADODB._Connection if present
2) If not successful, do it again and select Browse:
3) search and select Microsoft Activex Data Objects (not sure about the correct version: I'd choose the more recent)
4) in the lisbox below, select _Connection
Message Edited by pincpanter on 09-01-2009 02:12 PM
Paolo
Message 10 of 12
(5,478 Views)
