Database- insert and export PDF files from an extern Server
Hey,
I want to insert PDF in my Database. I've found the possibility to do this with the BLOB File Format. Acutally my test server is an extern PC.
I can insert files from the lokal PC by using this Query and the the execution VI from Labview:
NSERT INTO [dbo].[PDFTESt]
([PDF])
SELECT BulkColumn
FROM OPENROWSET( BULK 'C:\Users\SERVERCOMPUTER\Downloads\export_20201029-09_30_53.pdf', SINGLE_BLOB) as ExternalFile
but this do not work with the path from my own pc.
is there a way to insert Files from extern PC.
In the future  different user should be able to insert PDFs into the database.
And it should  be possible download the files .
Message 1 of 10
(3,102 Views)
This is not a LabVIEW problem. If I correctly understood, you are submitting the query from the Client PC but the file path must be valid on the Server. Correct?
If the query must refer to a file local to the Server, I can see basically two options:
1) move the file to the server some way (e.g. by means of a FTP server or a read-write shared folder) and then insert it
2) setup a shared folder on the Client, let's suppose 'Shared_files', which could be read-only : '\\MYOWNPCNAME\Shared_files\export_20201029-09_30_53.pdf'
Paolo
Message 2 of 10
(3,076 Views)
ok, but the other question:
I can save the PDF File into the Database as a varbinary File.
I am able to load the varbinary file with the "SELECT" Query. How can I transport this file into a PDF on the ClientPC ot just show the PDF on screen?
Message 3 of 10
(3,068 Views)
I never worked with BLOB format fields. Are you able to get the BLOB binary content into a LabVIEW string?
If yes, the obvious suggestion is to store this string into a newly created file, name it as .pdf and possibly open it by means of the windows shell.
Paolo
Message 4 of 10
(3,052 Views)
how can i save the string as a new file ?
Message 5 of 10
(3,048 Views)
Use Write to Binary File in the File I/O palette, wiring your string to the Data input. Wire False to prepend array or string size? (T).
Paolo
Message 6 of 10
(3,035 Views)
If i try to insert the binary file i get theis error:
ADO Error: 0x80040E14
Exception occured in Microsoft OLE DB Provider for ODBC Drivers: [Microsoft][ODBC SQL Server Driver][SQL Server]Implicit conversion from data type varchar to varbinary(max) is not allowed. Use the CONVERT function to run this query. in NI_Database_API.lvlib:Rec Create - Command.vi->NI_Database_API.lvlib:Cmd Execute.vi->NI_Database_API.lvlib:DB Tools Insert Data.vi->writebinarytodb.vi
wich convert function should I use for this?
Message 7 of 10
(3,003 Views)
On your first post you said you were able to insert. Did you change something?
Can you show your code?
Paolo
Message 8 of 10
(2,994 Views)
i use this VI the problem is the conversion into a varbinary. if I try it with the CONVERT function i get a syntax error.
and i cant copy the converted data into my DBMS and try it there. Does anyone have expierences with this?
Message 9 of 10
(2,870 Views)
Hello. Convert binary to base64.
Save it to varchar field. The lenght of varchar need to be >= lenght of encoded string.
Manuel
Message 10 of 10
(2,743 Views)
