Database access
Hello there
is there a way to access a MS-Access-Database with
LabView 5.1?
I don't have the SQL-Toolkit. I only want to
write/read data into/from an
Access-Database-File.
Thanks.
Saendu
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,146 Views)
In article <7tsdlt$ip9$1@nnrp1.deja.com>, saendu@my-deja.com writes:
>Subject: Database access
>From: saendu@my-deja.com
>Date: Mon, 11 Oct 1999 10:20:52 GMT
>Hello there
>LabView 5.1?
>Thanks.
>Saendu
I don't know whether Labview supports it, but Bridgeview can use ODBC to access
database files. Be careful, though, because Access has some quirks with regard
to ODBC. If it is supported, it is covered in the Labview docs and help files.
Samuel Friedman
FriedSH@aol.com
The reply address is spambloocked. Please use the address in the signature to
reply.
(3,146 Views)
I know how to read and write datas in Access from Labview : I use Active X. If you are interested write me to my adress : jmmoulard@caramail.com
But I have still a problem : I don't know how to create a table in Access from Labview using activeX! If you have learnt things about activeX since your question, maybe you can help me?
Thanks.
(3,135 Views)
